IHC Member 1110 |
Welcome Ken!If you look around the edge of the case back on your Waltham, if it is a snap case, you should see a small slot, usually on the right hand side up near the bow.You can use a case opener if you have one, or a small knife blade, and carefully pry it off.There's no way to identify it without opening the case, but it looks like a 10 or 12-size from the 30-40's.Hope this helps....Ted. | |||
IHC Life Member |
Ok - I managed to locate a blade that was perfect (slightly curved, dull enough to not slice my fingers if it slipped...). No slot, but (as I already knew) a wide spot on the rim of the back. A little force, and pop! So, from the innards, I have learned: Colonial Waltham, USA. Model 1924 Year of production : about 1935 (based on serial number) 17 Jewels Adjusted for Temperature NOT Railroad grade (no reason to think that it was!) So - any opinions on where this fits in Waltham history? Here's a picture: Kenneth Sloan ![]() | |||
Administrative Assistant |
Please post response to Kenneth's question in this topic... Waltham Colonial 1924 model, 17J, made in 1935 ...so as to keep all information in one place. Thank you. ![]() | |||
Hello Everyone I'm Back.. For 44 years working on the Railroad I carried a waltham up - dn 23 jewel movement or my trusty hamilton 950B. But I retired This March so I try not to think about time or what day it is for now. I still have my Omega Mk4 stainless. Since it is still working perfectly I wear it out. Cant beat an Omega still keeping time since 1970 when I bought it. | ||||
IHC Life Member |
Well...I've been assimilated. Since my last post in this thread, my collection has grown from the post-production 992B given to me as a graduation gift in 1970 AND my grandfather's Waltham (look two posts up) to...about 45 beauties ranging from an 1879 Elgin to the 992B (I'm unlikely to find one I want to collect that is NEWER than that one!) Most are RR grade, or precursors. My answer to the original question in this thread has changed. My goal is to put every one of my acquisitions into service (with proper care, of course). So...after having worn 1 pocketwatch for about 5 years and then another for about 45 years, I now rotate weekly. This week, I'm visiting Illinois, so I'm wearing a nice looking 1900 Rockford 545 (16s, 21j). Perhaps the 1879 Illinois model 1 (key wind and set, 18s, 11j) would have been a better choice, but it's still in the shop. Champaign (where I am right now) is a bit far from Rockford, but that's as close as I could get. Random query - is it possible to repair keys? The 1879 Illinois came with a distinctive key that has been rounded off to the point where I'm uncomfortable using it to wind or set. Can it be saved (either by reforming or replacing the business end)? At first glance, it appears to be a standard key set into a fancy holder. I sent it in to my repair guy with the watch, and I'm waiting to hear his verdict. What say you? Kenneth Sloan | |||
IHC Life Member |
Here are iPhone pictures of the Rockford, taken minutes ago...first the front Kenneth Sloan | |||
IHC Life Member |
and the back: Kenneth Sloan | |||
IHC Member 1110 |
Nice Rockford, Ken! That key should be repairable,you may be able to shorten it enough to make it good again if the square hole is deep enough. | |||
IHC Member 1110 |
This week I'm running my "new" Elgin, an 18s 17J Overland, one I've hunted a long time for.Rob Carter did a great job getting it cleaned up and running!These Overland's are a sharp looking movement. | |||
and not many made for sure. | |||
IHC Life Member |
My watches rotate into my pocket weekly. Here's this week's carry: (5 posts - 1 view each, starting with...the Front: Kenneth Sloan ![]() | |||
IHC Life Member |
Bezel off: Kenneth Sloan ![]() | |||
IHC Life Member |
Back: Kenneth Sloan ![]() | |||
IHC Life Member |
Inside of back: Kenneth Sloan ![]() | |||
IHC Life Member |
movement Kenneth Sloan ![]() | |||
IHC Life Member |
Here's what's in my pocket, this week: an 1896 Illinois Bunn Special. Many pictures, starting with this overview: Kenneth Sloan ![]() | |||
IHC Life Member |
front Kenneth Sloan ![]() | |||
IHC Life Member |
back Kenneth Sloan ![]() | |||
IHC Life Member |
Bezel off Kenneth Sloan ![]() | |||
IHC Life Member |
Bunn Special Movement number: 1335010 Kenneth Sloan ![]() | |||
IHC Life Member |
inside back Kenneth Sloan ![]() | |||
IHC Life Member |
inside dust cover Kenneth Sloan ![]() | |||
IHC Member 1110 |
This last 2 weeks, using my new 16s 17 jewel Illinois Bunn.Keeping about perfect time!I really like these 17-19J railroads! | |||
IHC Member 1110 |
Being a certified Hampden collector, I've been wanting a nice 16s Hampden RR watch for a daily carrier.I just got a beautiful 21J 5th model No. 105 movement from member Barry Hanstein, cased it in a base metal Emperor case,and now using it for work.Keeps railroad time.Already had a 105, but being in a gold filled case,I didn't want to use it too much.These 105's are Hampden's "992"! Great watches. | |||
IHC Life Member |
My carry for the next week. 1904 Ball Elgin. First the front - movement in the next post. Kenneth Sloan ![]() | |||
IHC Life Member |
and, the movement: Kenneth Sloan ![]() | |||
Looks like this post has been around for some time but as a new member thought I would put up a current post; I prefer the 12 Size since they easily fit into the watch pocket on Wrangler and Levis jeans as well as some Khaki Chinos that still have watch pockets. This just makes the 12 size very practical for daily wear if you are not wearing a vest. cheyenne56 | ||||
IHC Life Member |
With practice, an 18s works in the watch pocket of Levis 501 jeans: Kenneth Sloan ![]() | |||
IHC Life Member |
a not-so-successful iPhone shot of the movement: Kenneth Sloan ![]() | |||
IHC Member 163![]() |
True. I also carry several different 18s watches in rotation with my 16s. ![]() Regards! Mark | |||
IHC Life Member |
of course, 16sz also works: Kenneth Sloan ![]() | |||
IHC Life Member |
IHC Member 2030 |
New to me arrival from Mark Clark sale on IHC185. 992 #1344391 Very pleased,I did not carve HAM on back. ![]() | |||
Powered by Social Strata | Page 1 ... 8 9 10 11 12 13 14 ... 18 |
