Polishes? "Click" to Login or Register
Picture of David Johnson
posted June 15, 2003 14:36
How about some input on the types of metal polishes you prefer. I have three different types that I use each with varied results but have found nothing that stands out above the rest.
For those of you that polish your cases, what is your polish of choice?
Posts: 606 | Location: Dade City, Florida USA | Registered: December 12, 2002
posted June 15, 2003 14:43
I use Simichrome Polish. It containes no abrasives so it will not cause too much wear on the gold and leaves a protective finish behind. I have found this to be the best so far.
posted June 15, 2003 15:45
I use this metal polish. Can be found at Wall-Mart . Especially great for gold (they also make a product for silver only, although I haven't tried that one). I then follow it up with a jewelers polishing cloth. I like it because it is non-abraisive and easy to use. Just follow the directions.
Good luck.
Phil Dellinger
NAWCC# 157070
IHC Life Member (L12)
Posts: 993 | Registered: November 22, 2002
Picture of Bruce Byrd
posted June 15, 2003 17:06
I use the Simichrome polish also. I usually follow up with my jewelers cloth which brings everything up to a brilliant shine.
Picture of John D. Duvall
posted June 15, 2003 21:21
I like "Flitz" Metal Polish and Fiberglass Cleaner in the squeeze tube.
You have to search around for it and it ain't cheap but it does a very nice job.
John D. Duvall
NAWCC Member 144772
NAWCC IHC Happy Camper 192
posted June 15, 2003 21:35
I too use Simichrome with pretty good results. I also use a product called Maas polish but it can be a little stubborn to remove as you don't let it haze up. You remove it wet then buff. This is a little problematic with deeply engraved cases.
I'll have to give the Flitz polish a try.
Any others?
posted June 15, 2003 22:13
David,
I find the Flitz to be really good also. I tried some at Johns and it works very well. I use the Simichrome because it is available at the local Ma & Pa hardware store. I try not to patronize the "Big Guys" whenever possible.
