Elgin Grade 71Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Recently I won a Elgin Grade 71 Model 1 and I am having a hard time locating information on it Complete Price Guide To Pocket Watches. Looking to see if anyone is able to point out where I can locate that info. The watch is a size 6s with 17 jewels, serial number 3006895. Case is 18k multi colored gold with a 1/4 carat diamond on the front cover and a 1/10th carat diamond on the back cover. Thank you for any input you have! Ryan Schoenike ![]() | |||
Back cover Ryan Schoenike ![]() | ||||
Movement Ryan Schoenike ![]() | ||||
Dial Ryan Schoenike ![]() | ||||
Check out Wayne Schlitt's Elgin Watch Collectors Site. I'm not an Elgin collector but have always found it helpful. | ||||
grade total runs first yr last yr class size code jewels Adj/name ----- ----- ----- -------- ------- ----- ---- ------ ------ ---------- 71 5000 4 1877 1888 49 6s h3n1l 17j Adj (*) notes on grade 71: first 6s 17 jewel # Elgin MCs say some were 8s Class 49: 6s HC 3/4 lever model 1 71 5000 made 17j Adj Elgin MCs say some were 8s | ||||
Grade: 71 Manufacturer: Elgin Manufacturer Location: Elgin, Illinois Movement Serial Number: 3006895 Grade: 71 Model: 1 Class: 49 Estimated Production Year: 1889 Run Quantity: 1,000 Total Production: 1,000 Size: 6s Jewels: 17j Jewel Material: Ruby Jewel Setting: Screw-Set Movement Configuration: Hunting Movement Finish: Nickel Movement Setting: Lever Plate: 3/4 Plate Barrel: Going Train: Quick Regulator: Plain Adjusted: Yes Railroad Grade: No U.S. Patents: 77078 Data Research: c.1950 Elgin Serial List Research Note: #3006659: Verified as 6-Size [*****] | ||||
| IHC Member 1610 |
Well I can see we have two different totals. One source says 5000 and one says 1000. The Elgin resource link on this site says 5000 total. The other source says a total of 1000. I found that the online database says 1000. I don't know the source of the 1000 total listed here but I don't trust the online database as anyone can contribute any info they wish on that site and a lot of bad information is on there. But anyway you know that either 1000 or 5000 total which for Elgin both are low production runs. Harry | |||
| Administrative Assistant |
Gorgeous movement and case! | |||
A real Beauty !! regards, bb | ||||
Harry - The Grade 71 was produced in four separate runs. The first three runs are Size 8 (Total Production: 4,000) and the last run is Size 6 (Total Production: 1,000). | ||||
| IHC Member 1610 |
Thanks Nathan. Man that is weird to have the same grade in to different sizes. But that may be common for Elgin I am not that familiar with Elgin. Beautiful watch! Harry | |||
That clears it up. Thanks for everyone's help and comments! Ryan Schoenike | ||||
