McClintock clock Second hand does not turn consistently "Click" to Login or Register
Picture of Dave Turner
posted October 26, 2013 13:15
My McClintock clock works great except the second hand won't turn consistently.
This picture shows the second hand gear on top (still attached to the second hand) and the hour hand below.
I can see that the gear shows a wear pattern circle that indicates that the 3 pronged retainer has been turning against.
I've never had one of these apart and don't know how to get this one apart.
Can someone advise me how to proceed?
Should the retainer and the gear be locked together or should they turn?
How do I take it apart to clean it?
Dave Turner
posted October 26, 2013 13:34
Here's another picture showing both sides.
The large flat gear turns somewhat freely on the shaft. (And I don't think it should?)
How can I tighten it up?
Dave Turner
posted October 27, 2013 15:08
Didn't get an answer here, so I experimented a little.
I wrapped one turn of dental floss under the 3 prong retainer to tighten it up. (For anyone who might experience the same problem.) I'm sure this is not a proper repair, but it works! Smile
Clock now working fine and keeping good time. Not bad for a 1946 clock!
Dave Turner
Moderator
Picture of Donald Trumble
posted October 29, 2013 17:17
Ingenuity Big Grin will never let you down.
What you did is along the line of tightening the cannon pinion on a pocket watch by winding a human hair in the same manner as you used the dental floss. That was often done in repairing watches back when getting it operational counted most. You performed a simple repair that simply works.
Congratulations on repairing a good looking clock.
What is the overall diameter?
Don
Posts: 504 | Location: Pennsylvania in the USA | Registered: April 02, 2005
posted October 29, 2013 17:22
Thanks Don,
She's still running strong on the wall above the stove.
It's a 5 1/2" dial - 1946 McClintock. I picked it up out of a dumpster probably 20 years ago.
I think it's the same company that made the old clocks like you used to see in front of banks, depots, etc.
http://www.chapter124.org/acti...ck_clock_restore.pdf
Dave Turner
Moderator
posted October 29, 2013 17:57
Saving interesting items is what defines this hobby.
Don
