Accutron 218 - Second hand sweeps but minute and hour hand do not moveGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I have a 218 that the minute hand and hour hand do not move. When setting the watch the date and the hands appear to move fine. Any ideas? Thanks Clint | |||
My first guess would be slipping center wheel assy. | |||
I have a 219 with the same problem, what is involved in repairing it ? is it worth it ? John | ||||
| IHC President Life Member |
It is a reasonably easy repair and is definitely worth doing or having done. Consider the age of these watches and how long it may have been since they were last serviced. Tuning-Fork Accutrons are high quality jeweled movements that are an important part of Horological and American History. Check this... "Find-Or-Search" for "Accutron" Lindell | |||
There are a few things you can do to the cannon pinion to extend the life for a litle while longer before having to find another part. | |||
I live in ohio and the local jewlry store that sells Accutrons wont work on it. With all I have heard about watch makers not knowing how to fi Accutrons, How do I find someone that has the knowledge to do this work ? John | ||||
Hi John, Most jewelry stores simply take in work and pass it on to someone they know who does the work, as with the jewelry repairs etc a tiny percentage have a real trained watchmaker anymore, I have two store of the better stores I do work for in town and I can get anything from simple crown , quartz watches to fix, crystal, stem replacement to complicated wrist watches & pocket watches presented to you which is fun to keep hand in all these types and very profitable work, the jewelers simple marks up the job often 100% or more for handling it work and dont forget sales tax to often the cost of shipping to a watchmaker out of state | |||
| IHC Life Member Watchmaker |
Hi Everyone, This is a very common problem with Accutrons. Could be a blockage on the dial side gear train. Could be that someone removed the hour and minute hand and lifted the cannon pinion and hour wheel out of the train. Then you would only need to take off the dial and push the hour wheel and cannon pinion back down. Then put a dial washer on if there isn't one. Always pull the stem out when messing with the hands. If the second hand is still going around, you know that the index wheel,second wheel, and third wheel are moving. If you take a good look and can see that the fourth wheel is moving too, then you know that the problem is under the dial or with the arbor or pinion that joins the fourth wheel to the dial side wheels. | |||
here is a picture of the trouble maker ![]() | |||
