Lander on 4750 13-j electric Any idea what battery this takes? Thx | |||
389 battery will fit the old one is WD-4 These watches originally took the WD-4. Today you can use a standard silver oxide 389 battery; this has a smaller diameter and is thinner than the WD-4 so you should use a small non-conductive spacer for the modern 389 plus a small spring between the +ve terminal and the case back. Although a 386 appears to be a better fit, it is slightly too thick and causes the case back to flex inwards and touch the movement; this then shorts out the battery. FOUNDED ON INTERNET | ||||
