Landeron 4750 13 jewel electric "Click" to Login or Register
Picture of Phil Richardson
posted July 28, 2015 20:44
Lander on 4750 13-j electric
Any idea what battery this takes? Thx
Posts: 19 | Location: Colorado | Registered: January 31, 2010
Picture of Peter Kaszubski
posted July 28, 2015 21:19
389 battery will fit the old one is WD-4
These watches originally took the WD-4. Today you can use a standard silver oxide 389 battery; this has a smaller diameter and is thinner than the WD-4 so you should use a small non-conductive spacer for the modern 389 plus a small spring between the +ve terminal and the case back. Although a 386 appears to be a better fit, it is slightly too thick and causes the case back to flex inwards and touch the movement; this then shorts out the battery.
FOUNDED ON INTERNET
