July 28, 2015, 20:44
Phil RichardsonLanderon 4750 13 jewel electric
Lander on 4750 13-j electric
Any idea what battery this takes? Thx
July 28, 2015, 21:19
Peter Kaszubski389 battery will fit the old one is WD-4
These watches originally took the WD-4. Today you can use a standard silver oxide 389 battery; this has a smaller diameter and is thinner than the WD-4 so you should use a small non-conductive spacer for the modern 389 plus a small spring between the +ve terminal and the case back. Although a 386 appears to be a better fit, it is slightly too thick and causes the case back to flex inwards and touch the movement; this then shorts out the battery.
FOUNDED ON INTERNET
