  Horological Discussions, Questions and Answers   All Wristwatches Discussion Forum
  All Wristwatches Discussion Forum   Elgin 18/0 Stem Removal
  Elgin 18/0 Stem Removal| Go   | New Topic   | Find-Or-Search   | Notify   | Tools   | Reply to Post   |   |
 Does anyone have any tips on removing the stem on this movement? I have loosened and even removed the stem set lever screw and it still won't pull out I need to remove to get movement out of case so I can't get to the stem from the dial side...should I try removing the train bridge? Thank...Mark | |||
 I forgot to mention this is the first model, 483 grade.............Mark | ||||
 Note the stem set lever,I was able to remove the dial since screws were on the hand side | ||||
 the 484 movement after clean and oiling | ||||
 A good view of the watch,Thanks Ed for the site help I am a newbie at this so the pics aren't the best.Turns out the set lever screw had to be turned into the movement to release the stem unlike the newer movements I have worked on where the set screw is turned counter clockwise.It is running great and keeping good time for a 1927 elgin in a 14 k wadsworth case | ||||
