Elgin 18/0 Stem Removal "Click" to Login or Register
Does anyone have any tips on removing the stem on this movement? I have loosened and even removed the stem set lever screw and it still won't pull out I need to remove to get movement out of case so I can't get to the stem from the dial side...should I try removing the train bridge?
Thank...Mark
Posts: 100 | Location: Virginia in the USA | Registered: May 10, 2009
I forgot to mention this is the first model, 483 grade.............Mark
Note the stem set lever,I was able to remove the dial since screws were on the hand side
the 484 movement after clean and oiling
A good view of the watch,Thanks Ed for the site help I am a newbie at this so the pics aren't the best.Turns out the set lever screw had to be turned into the movement to release the stem unlike the newer movements I have worked on where the set screw is turned counter clockwise.It is running great and keeping good time for a 1927 elgin in a 14 k wadsworth case
