Illinois Watch Company Research Forum
18 size 17 jewel Bunn balance staff part numberGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 1614 |
Hi, I've got a 18 size 17 jewel Bunn that needs a balance staff. Does anybody have the part number? Thanks Bill | ||
| IHC Member 1614 |
The serial number is 1504233, variety 2 wavy pattern movement. Bill | |||
Grade: Bunn Movement Serial Number:1504233 Grade:Bunn Model: 6 Estimated Production Year: 1900 Open Face If you feel comfortable sharing a picture of the balance wheel we might be able to narrow your staff search down a little. The Model 6 came in DR/SR version. Staff # 47604 DR or 47605 SR (small collet) are the most common for the Model 6 from my search. Also, there is # 47632 which is a SR w/ large collet found in some Model 4 and 6. Good times!!! | ||||
| IHC Member 1614 |
Thanks Jon, I'll get a picture up Bill | |||
| IHC Member 1614 |
Sorry it took so long here is the balance Bill | |||
| IHC Member 365 |
Reminder: 18s open face staff is "short", hunting is "long". Earlier watches used large collet, later were small collet. Example: 18 size open face 17j. grade 69, serial number 1,xxx,xxx would use staff SINGLE ROLLER, SHORT, SMALL COLLET. I suggest tracking down a copy of the C.E Marshall Handy Manual, American section, IMHO the clearest guide to American pocket watch staffs. Learn the movement Models and forget the serial numbers. | |||
| IHC Member 1614 |
Thanks for your advice Bill | |||
The movement is an Open Face model 6 single roller, so the collet is either a Open Face 6886 large or 6890 small collet. That "collet" is a function of the hole size in the cross arm of the balance wheel. I would suggest you remove the staff, measure the collet diameter on the staff and order the part number noting the diameter of the collet. (fyi, I also marked the 6885 SR staff for Hunting movements. This WILL NOT work on your movement.) ![]() | |||
| IHC Member 1614 |
Thanks to all for your help. Another Bunn is now up and running! Bill | |||
