18 size 17 jewel Bunn balance staff part number "Click" to Login or Register
IHC Member 1614
posted January 10, 2015 22:33
Hi, I've got a 18 size 17 jewel Bunn that needs a balance staff. Does anybody have the part number? Thanks
Bill
posted January 10, 2015 22:53
Hi Bill,
Do you know if the staff is a Single Roller (SR) or a Double Roller (DR) (Part # 47604, 5.90mm in length- 6th model)? If the staff needed is a SR the serial # of the movement will be needed to help narrow down the staff by the model #.
I have a few of each...
IHC Member 1614
posted January 11, 2015 00:03
The serial number is 1504233, variety 2 wavy pattern movement.
Bill
posted January 12, 2015 16:52
Grade: Bunn
Movement Serial Number:1504233
Grade:Bunn
Model: 6
Estimated Production Year: 1900
Open Face
If you feel comfortable sharing a picture of the balance wheel we might be able to narrow your staff search down a little. The Model 6 came in DR/SR version. Staff # 47604 DR or 47605 SR (small collet) are the most common for the Model 6 from my search. Also, there is # 47632 which is a SR w/ large collet found in some Model 4 and 6.
Good times!!! Big Grin
IHC Member 1614
posted January 13, 2015 09:27
Thanks Jon, I'll get a picture up
Bill
IHC Member 1614
posted January 17, 2015 11:33
Sorry it took so long here is the balance
Bill
posted February 06, 2015 10:58
Reminder: 18s open face staff is "short", hunting is "long". Earlier watches used large collet, later were small collet. Example: 18 size open face 17j. grade 69, serial number 1,xxx,xxx would use staff SINGLE ROLLER, SHORT, SMALL COLLET. I suggest tracking down a copy of the C.E Marshall Handy Manual, American section, IMHO the clearest guide to American pocket watch staffs. Learn the movement Models and forget the serial numbers.
IHC Member 1614
posted February 12, 2015 00:45
Thanks for your advice
Bill
posted February 12, 2015 12:52
The movement is an Open Face model 6 single roller, so the collet is either a Open Face 6886 large or 6890 small collet. That "collet" is a function of the hole size in the cross arm of the balance wheel. I would suggest you remove the staff, measure the collet diameter on the staff and order the part number noting the diameter of the collet.
(fyi, I also marked the 6885 SR staff for Hunting movements. This WILL NOT work on your movement.)
IHC Member 1614
posted February 15, 2015 08:03
Thanks to all for your help. Another Bunn is now up and running!
Bill
