|  | posted |
Turn this around? I would like to know if there is a program that can make this the normal way? Thank you
Sheila
| | | Posts: 3094 | Location: La Plata, Maryland U.S.A. | Registered: May 22, 2004 |
IP
|  | posted | |
 Hi Sheila, Yes. Do you have windows Paint? |
| | | Posts: 315 | Location: Los Angeles, California USA | Registered: April 07, 2005 |
IP
|  | posted | |
Hi Barbara, Yes I do, however I never use it, but will try if that's what it takes. Fill me in OK?
Sheila
IP
|  | posted | |
YAY!  Can you open it? |
IP
|  | posted | |
yes, and I have the picture in it.
Sheila
IP
|  | posted | |
okay, now you're cookin'.  Go to file, edit, view, IMAGE . . . .click on image, choose the flip/rotate option. There will be a little window that should say flip or rotate - choose flip horizontal then okay. Let me know what happens next.  |
IP
|  | posted | |
YOU ARE OUTSTANDING!!! Thank you, Thank you.
Sheila
IP
|  | posted | |
I had no idea that I could do that!!! Thank you so much.
Sheila
IP
|  | posted | |
Oh cool, Sheila. You'd do the same for me.  Play around with it because it has features that other programs don't have and it's fairly easy to use. YAY! |
IP
|  | posted | |
I will INDEED check this out a lot more. Thanks again.
Sheila
IP
