August 13, 2005, 01:34
Sheila GilbertIs it possible to.........
Turn this around?
I would like to know if there is a program that can make this the normal way?
Thank you
August 13, 2005, 01:51
Barbara Barnes
Hi Sheila,
Yes.
Do you have windows Paint?
August 13, 2005, 01:57
Sheila GilbertHi Barbara, Yes I do, however I never use it, but will try if that's what it takes.
Fill me in OK?
August 13, 2005, 02:10
Sheila Gilbertyes, and I have the picture in it.
August 13, 2005, 02:15
Barbara Barnesokay, now you're cookin'.
Go to file, edit, view, IMAGE . . . .click on image, choose the flip/rotate option.
There will be a little window that should say flip or rotate - choose flip horizontal then okay.
Let me know what happens next.
August 13, 2005, 02:26
Sheila GilbertI had no idea that I could do that!!!
Thank you so much.
Barbara BarnesOh cool, Sheila.
You'd do the same for me.
Play around with it because it has features that other programs don't have and it's fairly easy to use.
YAY!
August 13, 2005, 02:27
Sheila GilbertI will INDEED check this out a lot more.
Thanks again.
