 | |  | posted |
 Turn this around? I would like to know if there is a program that can make this the normal way? Thank you
 Sheila
|  | | Posts: 3094 | Location: La Plata, Maryland U.S.A. | Registered: May 22, 2004 |  IP |
|  | |  | posted |  |
   Hi Sheila, Yes. Do you have windows Paint? |
|  | | Posts: 315 | Location: Los Angeles, California USA | Registered: April 07, 2005 |  IP |
 | |  | posted |  |
 Hi Barbara, Yes I do, however I never use it, but will try if that's what it takes. Fill me in OK?
 Sheila
|  | |  | posted |  |
 YAY!      Can you open it? |
 | |  | posted |  |
 yes, and I have the picture in it.
 Sheila
|  | |  | posted |  |
 okay, now you're cookin'.      Go to file, edit, view, IMAGE . . . .click on image, choose the flip/rotate option. There will be a little window that should say flip or rotate - choose flip horizontal then okay. Let me know what happens next.    |
 | |  | posted |  |
 YOU ARE OUTSTANDING!!! Thank you, Thank you.
 Sheila
 | |  | posted |  |
 I had no idea that I could do that!!! Thank you so much.
 Sheila
|  | |  | posted |  |
 Oh cool, Sheila. You'd do the same for me.      Play around with it because it has features that other programs don't have and it's fairly easy to use.   YAY! |
 | |  | posted |  |
 I will INDEED check this out a lot more. Thanks again.
 Sheila
