I’ve been on a mission for a quite a while looking for different pattern variants and have found a few.
It seems possible from the serial numbers the setup probably changed every hundred or less.
Following are 25 different images, the first two look very similar but there is a difference in the midway area and the outer band.
Some images are from online posts and the images are subpar. Some of these watches are mine and some are not.
If you can add that would be great.
My goal is to archive these here. I believe this is currently the only existing site with a collection of multiple pattern images.
They started in chronological order, but I've since found others.
Some of these appear to have taken much time to achieve.
Regards , Paul
6026151
