I’ve been on a mission for a quite a while looking for different pattern variants and have found a few.
It seems possible from the serial numbers the setup probably changed every hundred or less.
Following are 20 different images, the first two look very similar but I think there is a difference in the midway area.
Some images are from online posts and the images are subpar. Some of these watches are mine and some are not.
If you can add that would be great.
My real goal here is to archive these here , I believe this is the only place that now exists with a collection of these various patterns.
They started in chronological order, but I've since found others.
Some of these must have taken much time to achieve.
Regards , Paul
6026151
