Page 1 2 3 4 5 6 7 8 ... 12
Closed Topic Closed
In Search Of Seth Thomas "Click" to Login or Register
posted November 22, 2011 20:06
Shiela's s/n 350264 Seth Thomas 260 is a double roller. We had to replace the Staff and we used a Illinois staff with no difficulty.
posted November 26, 2011 22:06
The 382 may have been a late addition to the Model 5 family, as the ones I have seen have all been above the 300,000 range. This example sports a 3-foot genuine porcelain-enamel double-sunk dial.
My thanks to John Grennan for letting this one leave Arizona.
posted November 26, 2011 22:10
With a serial number nearly at the end of the Model 5 run, this two-tone 382 is a rare double-roller. The tip-off is the recessed well under the balance wheel. Double-roller escapes have two roller tables and no raised guide pin on the pallet fork.
Note the relocating of Safety Pinion to the edge of the balance away from the center pinion.
posted November 29, 2011 20:17
Another Model 2 in magnificent condition with a flawless Roman-numeral dial and matching hands:
posted November 29, 2011 20:19
A straight-nickel 15-jewel lever-set movement:
posted November 29, 2011 20:21
The beautiful Crescent 20-year case appears to be original to the watch:
posted December 08, 2011 19:05
A segment of the Model 5 parts list, showing some of the most sought-after pieces:
posted December 08, 2011 19:09
One of the more scarce named Model 5s is the Chautauqua. This example is fronted by a pale blue marked dial with pie-crust scallops where the inner sink would be if it had one, and a matching set of fleur-de-lis hands.
My thanks to our own William White for supplying the porthole. Smile
posted December 08, 2011 19:11
The movement is a lever-set unadjusted 15-jewel Grade 59 in excellent shape:
posted December 25, 2011 08:19
The Edgemere is another marked grade found in both Models 8 and 9, open-faced and hunter, respectively. What makes the Edgemere interesting is the number of variants found in this New Eagle grade. Examples came in both nickel and two-tone patterns, from 7-jewel up to 17-jewel.
Here is a Model 9 Edgemere showing the marked dial:
posted December 25, 2011 08:24
Backing that correct dial is an unusual 12-jewel two-tone variant. There are no jewels at all on the dial side, but the entire train is jewelled on the top plate.
I have not been able to find the connection between Seth Thomas and the name Edgemere. These can be found in both Edgemere, Chicago and Edgemere, USA markings. My thanks to our own Keith Klimkowicz for the movement.
posted December 25, 2011 08:28
All wrapped up in a nice Illinois hunter case:
posted January 22, 2012 17:57
The Trainmen's Special is another of the lesser marked grades, and can be found with or without the train on the dial.
posted January 22, 2012 17:58
It's a two-tone Model 12, and again has all those fake glass cap jewels.
My thanks to fellow New Yorker Roger Nolfe for his work on the hairspring.
posted January 22, 2012 17:59
All wrapped up in a nice Illinois case:
posted January 22, 2012 20:31
You are welcome Eric. That is a beauty of a case.
Roger
posted February 03, 2012 20:02
In the 1904 catalog Models 6 through 9 were referred to as Old and New Eagle series respectively, two for open-face and two for hunter movements.
An advert for a what appears to be a two-tone Model 8. Note the lack of a dust ring:
posted February 03, 2012 20:03
Here's my example of the same unusual two-tone 15-jewel lever-set Model 8:
posted February 03, 2012 20:17
It's fronted by a lesser Arabic dial, set off by light spade hands:
posted February 20, 2012 20:15
A recent addition is yet another variant of a 182, but this is a little different - it's not a two-tone, but an engine-turned gilt finish, with the pattern milled into the plates.
Thanks to Phil Sanchez for seeing this example safely home.
posted February 20, 2012 20:16
It's fronted by an excellent Roman dial with matching light spade hands:
posted February 20, 2012 20:17
Nicely tucked into a Champion watch case with a floral pattern:
  Powered by Social Strata Page 1 2 3 4 5 6 7 8 ... 12
Closed Topic Closed
