  South-Bend Watch Company Research Forum
  South Bend Movement Pictures, post your best...Go  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
| IHC Life Member  South-Bend  |
 I'm trying to build a database of South Bend movement pictures. The format I've decided on is 600x600 jpg pictures. If you want to make it a little bigger up to one side can be 650 pixels.  Eventually I'll be hosting them on the southbendhorology site. So I'm asking anyone that would care to post a picture to please do so as long as it is in jpg format and the largest side (height or width) is no more than 650 pixels. Of course, I'll start with a Grade 217, sn# 640662: ![]()  | ||
 Grade 281 - First Run ![]()  | |||
 Very worthwhile project, I'll help in any way I can. Here is a fairly common Grade 215 number 569136 which is a Model 2, Pendant-Set example of which about 20,000 were produced. ![]()  | |||
 Studebaker "8 adjustments. Serial No. 1208134 Dave Freeman IHC Member 321  | ||||
 South Bend 227 Serial No. 1019229 Dave Freeman IHC Member 321  | ||||
 More... ![]()  | |||
 So if you go to southbendhorology and scroll down to the bottom of the page you'll see that the images are being linked in. Please feel free to put up pictures of movements where the Grade has already been represented if you think you have a better picture.  | |||
 Next up a 21-Jewel "The Studebaker" Grade 229 Lever-Set Railroad Watch, which was the very best South-Bend Model 2, 16-size Open-Face movement. This one, number 584064 from about 1909 was the 64th one blocked out of only 3,000 produced. ![]()  | |||
 Next up, the Model 1 Grade 291. The 291 was the first 16s watch produced by the new South Bend Company. The one pictured is the 109th 16s to come off the production line. ![]()  | |||
 Here's a 293: ![]()  | |||
 I hate to be picky but the format of the picture should be as close to 600x600 as possible without any of the dimensions being larger than 600 (pixels). The pictures are going up on the SouthBendHorology site for now but are meant to be eventually included as part of the serial number lookup program. Also, just because a particular Grade of movement has already been posted please feel free to post another if you think you have a better picture. Thanks!  | |||
 Sorry.  Here is a 600 x 585 version  | |||
 The very busy looking Grade 298: ![]()  | |||
 A private label 260. ![]()  | |||
 The 417: ![]()  | |||
 For many years there were quite a few people who didn't believe the 417 was ever produced. It was: ![]()  | |||
 A common 292. ![]()  | |||
 The very common 281: ![]()  | |||
| IHC Member 48 |
 Frank WoW a Common 292 19jewel hunter! Nice picture. Sure wish I had a 292  | |||
 Keith, haven't seen any pictures from your collection. I know you have a few of the very hard to get models like the 304.  | |||
 The low-end entry into the market for South Bend, the 7j Grade 261. Between the 260 and the 261 about 40k watches total were produced. South Bend watches seemed to sell in pretty equal percentages across the quality range. ![]()  | |||
 Here's a first run 290. There were about 12k total produced although as with most hunting movements it's hard to find one in a proper case. And it's only going to get worse with the price of gold now. ![]()  | |||
 The 299. About 3k total produced. ![]()  | |||
 A Grade 341. About 6.5k total produced.  | |||
 A typical Grade 333 except for the private label marking. As far as I can tell there weren't many PL movements produced by South Bend. As for the 333, about 12k of them were made.  | |||
 The Grade 150. A nice little movement that was a little late to the party. Only about 1k of these were made. ![]()  | |||
 The humble Grade 203. A model 2 16s 7j watch. About 16k were produced. ![]()  | |||
| IHC Member 48 |
 The last of the hunters a grade 204 ![]()  | |||
 Grade 211, Circular-Damaskeening:  | |||
 Grade 211, Fish-scale damaskeening:  | |||
 Grade 211, First Damaskeening Pattern, Half-Checkerboard  | |||
 A first run Grade 411. The 12s movements originally started out with the serial number on the barrel bridge. ![]()  | |||
 The Grade 280. Excluding the 0s movements the 280 was the highest number of hunting case movements produced, about 16k. ![]()  | |||
| Powered by Social Strata | Page 1 2 3 4 |
