Balance Poising quiz (balance is grossly heavy one side)Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 1736 |
This balance is from a 17J 12s Illinois DR movement. S/N: 341080 Can you spot the problem? I put the heavy side down in both photos.... Laid the balance side by side with a known good balance from a similar movment... ![]() | ||
| IHC Member 1736 |
Silver speed screws threw me off for a minute. I was concerned someone might have harvested the gold. ![]() | |||
One half of the wheel rim is bent outward too far? Dave Turner | ||||
| IHC Member 1736 |
The curve on the arm is something I will have to address, but is only a minor contributor. This thing immediately goes to the heavy side. | |||
| IHC Member 1613 |
Difference in weight between a gold screw on the heavy side and a brass screw on the light side???Also, gold screw looks like a domed screw v. brass screws are flat.. | |||
| IHC Member 1736 |
It's pretty amazing how much difference in weight there is between a gold screw and a brass screw that for all intents and purposes are the same size. It was so far out of poise, I just sat and stared at if for a couple minutes, counting the weights, checking their locations, comparing to a known good balance in another watch... And then it jut jumped out at me that the one balance weight was a gold weight. The gold screw is rose gold in color and lacks the patina of the brass weights. Swapped in a pair of weights from a donor watch and she came right back to normal. | |||
| IHC Member 1851 |
I did some digging. Atomic weights: yellow brass 192.5 ;roughly 1part zinc 2parts copper / varies with alloy platinum 195 sometimes used for meantime screws gold 197 lead 207 some gold screws are very soft and easily scarred , this I think would indicate a high karat. | |||
