December 26, 2014, 12:18
Paul D. TrombleyBalance Poising quiz (balance is grossly heavy one side)
This balance is from a 17J 12s Illinois DR movement. S/N: 341080
Can you spot the problem?
I put the heavy side down in both photos....
Laid the balance side by side with a known good balance from a similar movment...
December 26, 2014, 12:21
Paul D. TrombleySilver speed screws threw me off for a minute. I was concerned someone might have harvested the gold.
December 26, 2014, 12:53
Dave TurnerOne half of the wheel rim is bent outward too far?
December 26, 2014, 13:19
Paul D. TrombleyThe curve on the arm is something I will have to address, but is only a minor contributor.
This thing immediately goes to the heavy side.
December 26, 2014, 15:19
Gary E. CochranDifference in weight between a gold screw on the heavy side and a brass screw on the light side???Also, gold screw looks like a domed screw v. brass screws are flat..
December 26, 2014, 17:14
Paul D. TrombleyIt's pretty amazing how much difference in weight there is between a gold screw and a brass screw that for all intents and purposes are the same size.
It was so far out of poise, I just sat and stared at if for a couple minutes, counting the weights, checking their locations, comparing to a known good balance in another watch...
And then it jut jumped out at me that the one balance weight was a gold weight. The gold screw is rose gold in color and lacks the patina of the brass weights.
Swapped in a pair of weights from a donor watch and she came right back to normal.
December 27, 2014, 13:42
Paul J. WilliamsI did some digging.
Atomic weights:
yellow brass 192.5 ;roughly 1part zinc 2parts copper / varies with alloy
platinum 195 sometimes used for meantime screws
gold 197
lead 207
some gold screws are very soft and easily scarred , this I think would indicate a high karat.
