Balance Poising quiz (balance is grossly heavy one side) "Click" to Login or Register
IHC Member 1736
This balance is from a 17J 12s Illinois DR movement. S/N: 341080
Can you spot the problem?
I put the heavy side down in both photos....
Laid the balance side by side with a known good balance from a similar movment...
IHC Member 1736
Silver speed screws threw me off for a minute. I was concerned someone might have harvested the gold.
Picture of Dave Turner
One half of the wheel rim is bent outward too far?
Dave Turner
IHC Member 1736
The curve on the arm is something I will have to address, but is only a minor contributor.
This thing immediately goes to the heavy side.
IHC Member 1613
Difference in weight between a gold screw on the heavy side and a brass screw on the light side???Also, gold screw looks like a domed screw v. brass screws are flat..
IHC Member 1736
It's pretty amazing how much difference in weight there is between a gold screw and a brass screw that for all intents and purposes are the same size.
It was so far out of poise, I just sat and stared at if for a couple minutes, counting the weights, checking their locations, comparing to a known good balance in another watch...
And then it jut jumped out at me that the one balance weight was a gold weight. The gold screw is rose gold in color and lacks the patina of the brass weights.
Swapped in a pair of weights from a donor watch and she came right back to normal.
I did some digging.
Atomic weights:
yellow brass 192.5 ;roughly 1part zinc 2parts copper / varies with alloy
platinum 195 sometimes used for meantime screws
gold 197
lead 207
some gold screws are very soft and easily scarred , this I think would indicate a high karat.
Posts: 211 | Location: Colorado Springs, Colorado in the USA | Registered: April 23, 2013
