is this a Main Spring issue?Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
hi everybody, Todd the novice initiate here. i have stopped calling myself "todd the beginner" i got one working so i have promoted myself to "novice" so, here is my question, as many of you know i just finished an 1884 elgin. when i gave it a full wind it seemed to be running fast, 18 hours later it seemed to be running slow. is this affect caused by an old weak M.S.? P.S. cleaned a nasty hairline crack on the dial from the center to 3:30 with a members trick. polident. to quote him, "this dial is bright, clean and minty fresh." Todd the novice ![]() | |||
Todd, In your COA did you clean the mainspring and re-grease or oil it? This will make a big difference in operation. (I'm assuming that the gear train is free ... no binding). Kindest regards, Serge | ||||
hi Serge, the gear train is smooth as silk in all positions, ran it with no pallet lever in place and it gave a nice little roll back when the MS ran out. i cleaned and greased the MS with KT-22 but had some problem getting the whole spring back in the barrel so i cut it in half. (joking) i think i am going to buy a new MS and see what happens. Todd | ||||
"Fast" and "Slow" have various causes depending on HOW "fast or slow" they are. | |||
hi David, on full wind it runs just under 2 minutes fast over 12 hours, then slows down over the next 12 hours. Todd | ||||
It sounds like your mainspring might be set. Try a new spring. | ||||
Todd are you changing position of the watch during testing? or staying face up for example? I understand you are just doing these movements for practice now, but when you get into watches you will be carrying it is always best to go ahead and install a new alloy mainspring if it has a blue steel mainspring. Alloy mainspring are far superior and typically last a long time and also you can avoid some of these issues like you are dealing with. Rob www.pocketwatchrepairs.net | ||||
Agreed ONLY if you intend to carry it. | |||
or if you are a lifelong perfectionist like me, if i don't do the best job i am capable of it will eat at me. thanks to everyone, a new alloy mainspring it will be for my beautiful 7 jewel wonder! Todd | ||||
