replacing the screw in the studGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I want to take a screw out of one balance asembly that has a broken staff and put it in another stud to fasten the hairspring to. Is there a good method as this is such a small screw and it is going into a small hole also. The only thing i could think of is maybe get something to make the end of my screwdriver sticky to hold the screw while i try to start the thread in the stud. Any thoughts on this ? | |||
| IHC President Life Member |
Kevin, Look out because this advice is heresy... A lot of my life's experience is automotive-related. There, magnets to retrieve nuts and bolts as well as magnetized tools to help hold a fastener while positioning are common-place. When I have to work with such a small screw I use a magnetized screw driver. Afterwards in order to be safe I demagnetize the movement. Not the recommended way but it works for me. Lindell | |||
Are you refering to the screw that holds the balance stud into the balance cock? If so watchmaker's tweezers (Dumont 3c is a great one) will be able to hold the screw. Be very warry of using any magnatized screwdrivers. magnatism can transfer and wind up in the hairspring. Mike Miller | ||||
veritas, Here is a slide that may help you out with tiny screws. John D. Duvall NAWCC Member 144772 NAWCC IHC Happy Camper 192 Chapter 185 Watch Repair Moderator ![]() | |||
Thanks John, i just saw your slide today and these are great ideas, i probaly have asimilar problem like other people do, small scre, getting older, eyes are not like they used yo be and you need lots of patience. You are a real asset to this chapter and keep up the great work. Kevin West | ||||
