general use cleaning liquid "Click" to Login or Register
I have a L and R , three jar cleaning machine.Would the ammonia based cleaner be the best one to start using in this and if it is could i just rinse in naptha after ?
Thanks again.
IHC Member 261
Chapter 111,Ottawa
NAWCC Member 158976,
Nepean, Canada
Picture of Brian C.
Veritas,
I use L&R Fine Watch Cleaning Solution, amonia based and L&R #3 Watch Rinsing Solution.
Brian C.
pwpartsetc@webtv.net
Picture of Grant Perry
Veritas:
I use #111 Ultrasonic Watch Cleaning Solution and Ultrasonic watch rinsing solution; although I manually clean my watches I live in the Ottawa area as well and I buy both at Geneva Watch Materials (130 Slater). The pricing is good as well.
Grant Perry
NAWCC #0157065
Chapter 111
IHC-185 #141
Posts: 334 | Location: Ottawa, Canada | Registered: January 28, 2003
IHC Member 229
Are these various cleaning solutions you are suggesting water based or petroleum based....I'm concerned about rust between screw threads and mating parts....I usually work on one watch at a time...I find a simple inexpensive utrasonic jewelery cleaner...does a fine job of cleaning just about any small part or parts...I'm still doing a certain amount of hand cleaning with a tooth brush and pegwood....it's the choice of the best all around solution that has me confused...I understand in the "good old days"...they used to use gasoline
Posts: 148 | Location: Somerville, New Jersey USA | Registered: November 28, 2002
Picture of David Fahrenholz
I use the same as Brian. Be sure not to leave in either solution too long. After rinsing dry right away with a drying box or hair dryer to get a great finish.
Viele Grüße
David Fahrenholz
Fahrenholz Clock & Watch
Timeless Service
Posts: 52 | Location: Fishers, Indiana USA | Registered: June 24, 2003
