August 07, 2003, 12:26
Kevin Pestorgeneral use cleaning liquid
I have a L and R , three jar cleaning machine.Would the ammonia based cleaner be the best one to start using in this and if it is could i just rinse in naptha after ?
Thanks again.
IHC Member 261
Chapter 111,Ottawa
NAWCC Member 158976,
Nepean, Canada
August 08, 2003, 04:30
Brian C.Veritas,
I use L&R Fine Watch Cleaning Solution, amonia based and L&R #3 Watch Rinsing Solution.
Brian C.
pwpartsetc@webtv.netAugust 20, 2003, 09:03
Grant PerryVeritas:
I use #111 Ultrasonic Watch Cleaning Solution and Ultrasonic watch rinsing solution; although I manually clean my watches I live in the Ottawa area as well and I buy both at Geneva Watch Materials (130 Slater). The pricing is good as well.
Grant Perry
NAWCC #0157065
Chapter 111
IHC-185 #141
August 20, 2003, 11:00
Tony CiccotelliAre these various cleaning solutions you are suggesting water based or petroleum based....I'm concerned about rust between screw threads and mating parts....I usually work on one watch at a time...I find a simple inexpensive utrasonic jewelery cleaner...does a fine job of cleaning just about any small part or parts...I'm still doing a certain amount of hand cleaning with a tooth brush and pegwood....it's the choice of the best all around solution that has me confused...I understand in the "good old days"...they used to use gasoline
August 20, 2003, 12:59
David FahrenholzI use the same as Brian. Be sure not to leave in either solution too long. After rinsing dry right away with a drying box or hair dryer to get a great finish.
Viele Grüße
David Fahrenholz
Fahrenholz Clock & Watch
Timeless Service
