general use cleaning liquidGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I have a L and R , three jar cleaning machine.Would the ammonia based cleaner be the best one to start using in this and if it is could i just rinse in naptha after ? Thanks again. IHC Member 261 Chapter 111,Ottawa NAWCC Member 158976, Nepean, Canada | |||
Veritas, I use L&R Fine Watch Cleaning Solution, amonia based and L&R #3 Watch Rinsing Solution. Brian C. pwpartsetc@webtv.net | ||||
Veritas: I use #111 Ultrasonic Watch Cleaning Solution and Ultrasonic watch rinsing solution; although I manually clean my watches I live in the Ottawa area as well and I buy both at Geneva Watch Materials (130 Slater). The pricing is good as well. Grant Perry NAWCC #0157065 Chapter 111 IHC-185 #141 | ||||
| IHC Member 229 |
Are these various cleaning solutions you are suggesting water based or petroleum based....I'm concerned about rust between screw threads and mating parts....I usually work on one watch at a time...I find a simple inexpensive utrasonic jewelery cleaner...does a fine job of cleaning just about any small part or parts...I'm still doing a certain amount of hand cleaning with a tooth brush and pegwood....it's the choice of the best all around solution that has me confused...I understand in the "good old days"...they used to use gasoline | |||
I use the same as Brian. Be sure not to leave in either solution too long. After rinsing dry right away with a drying box or hair dryer to get a great finish. Viele Grüße David Fahrenholz Fahrenholz Clock & Watch Timeless Service | ||||
