  Hamilton and 992B Research Forum
  Hamilton 950L I just got at a pawn shopGo  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
| IHC Member 1335 |
 A lovely 23 jewel Hamilton gold train 950L movement serial # 1150053 I got at the pawn shop day before yesterday     | ||
| IHC Member 1335 |
 #2  | |||
| IHC Member 1335 |
 #3  | |||
| IHC Member 1335 |
 #4 Don't know as I've seen a knurled gold flange on the crown post like this before??    | |||
| IHC Member 1335 |
 #5  C.W.C.Co.trade mark a 1/4 moon and a star Sterling #54161  | |||
| IHC Member 1342 |
 Hi Tom - wow - nice - you seem to be picking them up from everywhere! As for as the case goes, I have one - with one of those Knurled gold flanges on the crown post... they unscrew to come off. I have taken them off to clean before. Marc Micale  | |||
 Tom, Below the brass colored dust cover that does unscrew is a stem sleeve. of coarse you need a sleeve wrench to remove and replace. Since the bezel is in such bad shape it might be better to replace the case.  | |||
 Nice find Tom, Maybe the roller jewel broke or fell out? It's the same roller and jewel that's used on the 992. The 1917-1918 movement could be cased in anything period correct. Below is a catalog page showing one case style. The case it's in is also correct if it can be saved. If the threads are O.K. you could file down the sterling silver and fix the sleeve and or stem. Good luck, RR 1919 Hamilton Catalog, Page 19 ![]()  | ||||
| IHC Member 1335 |
 hi Richard; the roller jewel is in place. I removed the balance bridge and put it back in, and lo and behold it was running. Then I noticed that the hairspring was over the edge of the gear. I carefully placed it under but noticed that the hairspring is not between those two pins. Not much wrong with it for sure, thanks , and Merry Christmas  | |||
 Tom, I'm glad there wasn't much wrong with the 950L. It's nice when fixes are simple. Merry Christmas, RR  | ||||
| IHC Member 1335 |
 Took down the balance side ,the balance pivot jewels oil had evaporated down to black gum ,cleaned and oiled that side and away she went ,now she's running like a racehorse! I'm not set up to use an ultrasonic cleaner right now so for the time being I left the dial on but she should get a complete COA  | |||
