Help With Hamilton 912 (problem solved thanks all) "Click" to Login or Register
How to set the hands on this watch,don't want to force anything
Posts: 112 | Location: Scotland in the United Kingdom | Registered: October 17, 2013
watch face
IHC Member 163
Picture of Mark Cross
Every Hamilton 12S I've owned has always been pendent set.
Regards! Mark
Posts: 3840 | Location: Estill Springs, Tennessee, USA | Registered: December 02, 2002
the pendent is very hard to pull out and I don't want to force it any ideas.
I have found some pendant sets that from a lack of service and or a dirty or rusty stem/sleeve getting the pendant to pull out is difficult at best. Sometimes I will pull while rotating the crown and see if I can slip a bit of oil down the stem and once you can get the pendant to pop up remove the movement and remove any excess oil so that it does not go doing into the movement itself.
IHC Member 1736
Ron,
What did you figure out?
Paul
Paul,I just wasn't pulling it hard enough ,it is moving fine now.
IHC Member 1736
Some are just sticky for not having been operated in a long time.
Part of my routine is to break down the crown, stem and sleeve. Clean, lube and reassemble.
Frequently, I find a lip or ledge on the detente the sleeve has to ride over when the stem is pulled up to the "set" position. Or, the detente is simply far more aggressive than it needs to be in height or angle.
I've taken to chucking the stems up on my lathe, reshaping the detente with a jewelers file and polishing the detente it with 2000 grit sand paper wrapped around a file or stir stick.
