Vest Chain marked Simmons .33 "Click" to Login or Register
IHC Member 1736
posted January 08, 2013 16:33
I'm thinking a chain that came attached to a watch I just bought might be solid 8K...
Can anyone confirm the meaning of a Simmons watch chain stamped 33 or .33 for me?
Sorry the picture doesn't pull enough detail to see the stamp. All I know for sure is that is not a date stamp and it is not a 1/10 or 1/20 mark.
posted January 08, 2013 17:10
You can use a loop and go around the chain to look for any possible brassing - on the inside of the links where they rub together or the extreme edges/high pts...
It sure could be 8k chain...
The reason I say to use a loop, is because I have had chains pieced together, and a section or end is solid gold, and the rest is Gold Filled
Picture of Peter Kaszubski
posted January 08, 2013 23:12
Thats how I check my chains with the loop every link.
IHC Member 1291
posted January 08, 2013 23:40
I am fairly sure I have never seen anything but gold filled in the Simmon's chains.
IHC Member 1736
posted January 08, 2013 23:49
The chain checks out, solid all the way. Net weight is 8grams.
The round clasp at the other end has what looks to be an inspection hole drilled through on the inside radius. So, I can see that even that piece is solid.
Pretty cool
How far are you from Yuma or Quartzsite Peter? I'll probably make that run again in late February or early March.
posted January 09, 2013 01:10
I'm in Maricopa bout 15 miles south of Poenix.
Let me know perhaps we can meet at Quartzsite and I will drag Mike H from here with me Smile
IHC Member 1016
posted January 09, 2013 10:49
I'm good with that.
