Another Genuine made in USA Private Label "Click" to Login or Register
posted January 23, 2009 00:39
Beautiful hands, Eagle engraved movement, 3-Hinge case, Well executed Dial with famous Ohio Jeweler's name inscribed! Very easy to clean and "refresh" . . .
posted January 23, 2009 00:41
Who else could do a piece like this?!
Picture of Brian C.
posted January 23, 2009 11:16
Dave, hear are some pictures of a couple I have. Notice the different size of the eagles.
Brian C.
Picture of Brian C.
posted January 23, 2009 11:17
Movement
Picture of Brian C.
posted January 23, 2009 11:18
Watch #2
Picture of Brian C.
posted January 23, 2009 11:19
Movement #2
posted January 23, 2009 18:30
Brian both of yours are "Big Kahuna Hunters", so they get BIGGER eagles than my lowly Open Faced little chicken!
Picture of Jerry King
posted January 25, 2009 16:29
Some very nice private label's shown here....
This is a 12s movement that I recently found....
It is a Hennegen-Bates Company, double signed on the dial and movement.... the balance runs smooth but the second hand will not move so this one will need to go get fixed up a bit....
And it is in need of a hunter case also....
Any comments, please.... Big Grin
posted January 25, 2009 16:30
#2 - rear of movement
posted January 25, 2009 16:31
#3
Picture of Brian C.
posted January 25, 2009 17:19
Jerry,
Your watch is a 12s Illinois, model 2, grade 228, 15 jewels unadjusted, stem wind and set.
It looks like the second hand might be hitting the dial.
Brian C.
Site Moderator
Picture of Tom Brown
posted January 25, 2009 17:22
If your interested your watch was from a jeweler William H Hennegen, James O Bates & John D. Reynolds, they are listed in a 1890 Baltimore directory.
posted January 25, 2009 18:38
Thanks to both, Brian & Tom....
The second hand does clear the dial, close but not touching....the pallet fork does not move when the balance turns....
That info on Hennegen & Bates is good Tom....
I think finding a case is going to be difficult.... Confused
Picture of Mary Ann Scott
posted February 01, 2009 14:03
I just bought this private label Waltham P.S. Bartlett model 1877 #1239910 from Leonard Abbott and can't find any info on the movement name. Maybe someone can find out something. It's marked "Scharnke. V Will." or "Scharnke. & Will." Pittsburgh, PA.
Posts: 1047 | Location: The Colony, Texas in the USA | Registered: December 20, 2008
posted February 01, 2009 14:06
It looks to have been made in Dec. 1879. The cuvette is dedicated to A. Endres in 1880 so this is most likely the original coin case.
posted February 01, 2009 14:08
The dial is marked A.W.Co. Waltham. Any help is appreciated. Thanks!
Site Moderator
posted February 01, 2009 16:21
Mary Ann
It looks like the jewelery store that sold your watch was Scharnke & Will, which was Julius Scharnke & Chas C. Will, in the 1880 census Juiluis is listed as a watch maker.
Scharnke
Site Moderator
posted February 01, 2009 16:22
Chas Will
Will
posted February 01, 2009 17:20
I wonder of that means the Endres Family was local too and could be found. Hit first Initial is "N", could be Nathaniel.
Site Moderator
posted February 01, 2009 17:49
David
I also thought the same but searching for a N. Endres in Pa. I didn't have any luck. I will keep seeing if I can find something.
Site Moderator
posted February 01, 2009 20:12
Well so far living in that area with the last name Endres I find George, Jacob & John
Site Moderator
posted February 01, 2009 20:22
This is perhaps him, in 1881 there was a Adam Endres who was a tailor
endres
posted February 01, 2009 21:25
Hi Tom and David...it's actually A. Endres so the Adam may be him, if he did indeed live in Pittsburgh. The time frame is about right. I am impressed with the research sources that you have, Tom. You always seem to be able to track down info on anything we throw at you! Wink
Thank you for the scoop on Scharnkle & Will, also. I will let Leonard know, too, as he is curious.
posted February 02, 2009 12:21
Jerry, If the pallet fork doesn't move when the balance wheel spins you may have a broken or missing roller jewel. If you manually work the pallet back and forth, does the escape wheel rotate? If it does, that would indicate the train is free, which would once again point back to the roller jewel as being the culprit.
posted February 02, 2009 21:52
I like those watches with the eagle on the movement. Does anyone know when the eagle officially became the national bird? I have a swiss watch with the eagle on the case. It might help to date the watch.
Posts: 827 | Location: Bloomington, Illinois in the USA | Registered: September 29, 2008
Site Moderator
posted February 02, 2009 22:26
June 20, 1782
posted February 03, 2009 11:30
Well, that's way too early for my watch, of course. I don't think my eagle is a bald eagle, though. A little thin on top, but not bald. Is there any significance to the bird looking to the left, as opposed to the right?
posted February 04, 2009 23:39
Here is a little 12s eagle motif case that I am rather fond of. A higher grade Stewart Special will be going in it eventually.
