Another Genuine made in USA Private Label
January 23, 2009, 00:39
David AbbeAnother Genuine made in USA Private Label
Beautiful hands, Eagle engraved movement, 3-Hinge case, Well executed Dial with famous Ohio Jeweler's name inscribed! Very easy to clean and "refresh" . . .
January 23, 2009, 00:41
David AbbeWho else could do a piece like this?!
January 23, 2009, 11:16
Brian C.Dave, hear are some pictures of a couple I have. Notice the different size of the eagles.
Brian C.
January 23, 2009, 11:17
Brian C.Movement
January 23, 2009, 11:18
Brian C.Watch #2
January 23, 2009, 11:19
Brian C.Movement #2
January 23, 2009, 18:30
David AbbeBrian both of yours are "Big Kahuna Hunters", so they get
BIGGER eagles than my lowly Open Faced little chicken!
January 25, 2009, 16:29
Jerry KingSome very nice private label's shown here....
This is a 12s movement that I recently found....
It is a Hennegen-Bates Company, double signed on the dial and movement.... the balance runs smooth but the second hand will not move so this one will need to go get fixed up a bit....
And it is in need of a hunter case also....
Any comments, please....
January 25, 2009, 16:30
Jerry King#2 - rear of movement
January 25, 2009, 16:31
Jerry King#3
January 25, 2009, 17:19
Brian C.Jerry,
Your watch is a 12s Illinois, model 2, grade 228, 15 jewels unadjusted, stem wind and set.
It looks like the second hand might be hitting the dial.
Brian C.
January 25, 2009, 17:22
Tom BrownJerry
If your interested your watch was from a jeweler William H Hennegen, James O Bates & John D. Reynolds, they are listed in a 1890 Baltimore directory.
January 25, 2009, 18:38
Jerry KingThanks to both, Brian & Tom....
The second hand does clear the dial, close but not touching....the pallet fork does not move when the balance turns....
That info on Hennegen & Bates is good Tom....
I think finding a case is going to be difficult....
February 01, 2009, 14:03
Mary Ann ScottI just bought this private label Waltham P.S. Bartlett model 1877 #1239910 from Leonard Abbott and can't find any info on the movement name. Maybe someone can find out something. It's marked "Scharnke. V Will." or "Scharnke. & Will." Pittsburgh, PA.
February 01, 2009, 14:06
Mary Ann ScottIt looks to have been made in Dec. 1879. The cuvette is dedicated to A. Endres in 1880 so this is most likely the original coin case.
February 01, 2009, 14:08
Mary Ann ScottThe dial is marked A.W.Co. Waltham. Any help is appreciated. Thanks!
February 01, 2009, 16:21
Tom BrownMary Ann
It looks like the jewelery store that sold your watch was Scharnke & Will, which was Julius Scharnke & Chas C. Will, in the 1880 census Juiluis is listed as a watch maker.
February 01, 2009, 16:22
Tom BrownChas Will
February 01, 2009, 17:20
David AbbeI wonder of that means the Endres Family was local too and could be found. Hit first Initial is "N", could be Nathaniel.
February 01, 2009, 17:49
Tom BrownDavid
I also thought the same but searching for a N. Endres in Pa. I didn't have any luck. I will keep seeing if I can find something.
February 01, 2009, 20:12
Tom BrownWell so far living in that area with the last name Endres I find George, Jacob & John
February 01, 2009, 20:22
Tom BrownThis is perhaps him, in 1881 there was a Adam Endres who was a tailor
February 01, 2009, 21:25
Mary Ann ScottHi Tom and David...it's actually A. Endres so the Adam may be him, if he did indeed live in Pittsburgh. The time frame is about right. I am impressed with the research sources that you have, Tom. You always seem to be able to track down info on anything we throw at you!
Thank you for the scoop on Scharnkle & Will, also. I will let Leonard know, too, as he is curious.
February 02, 2009, 12:21
Bruce StewartJerry, If the pallet fork doesn't move when the balance wheel spins you may have a broken or missing roller jewel. If you manually work the pallet back and forth, does the escape wheel rotate? If it does, that would indicate the train is free, which would once again point back to the roller jewel as being the culprit.
February 02, 2009, 21:52
Steve GossardI like those watches with the eagle on the movement. Does anyone know when the eagle officially became the national bird? I have a swiss watch with the eagle on the case. It might help to date the watch.
February 02, 2009, 22:26
Tom BrownJune 20, 1782
February 03, 2009, 11:30
Steve GossardWell, that's way too early for my watch, of course. I don't think my eagle is a bald eagle, though. A little thin on top, but not bald. Is there any significance to the bird looking to the left, as opposed to the right?
February 04, 2009, 23:39
Bruce StewartHere is a little 12s eagle motif case that I am rather fond of. A higher grade Stewart Special will be going in it eventually.
