What kind of movement? "Click" to Login or Register
Picture of Larry Lamphier
posted August 01, 2012 20:33
I was wondering if anyone knew what this might be.
posted August 01, 2012 20:35
the piller plate
posted August 01, 2012 20:40
the case is No 18 fine silver, and it says cylindre 10Rubis, then Geneve.
The inside cover has a number 48862 and has the word CUIVRE after it.
By the way, the case number is the same as the movement number.
Thank you for any help.
the dial has no name
posted August 01, 2012 20:41
Everything came in this holder.
IHC Member 1610
posted August 01, 2012 22:37
Sorry Larry I can't hep but I like that minute hand.
posted August 02, 2012 00:47
Harry, It's a little rough, but if you want it I'll send it to you.
IHC Member 1610
posted August 02, 2012 01:12
Thanks Larry but I would not have an hour hand to match it. It would be cool if I did though.
Thanks anyway,
Harry
P. S. I heard about the case. Ouch!!! I hope you were able to save it.
posted August 02, 2012 11:09
Larry, the 10 Jewel Cylinder movement is the same as a 15 Jewel "normal" movement because the Cylinder has no Pallet fork reducing the "count" by 5 Jewels (2 pivot, 2 pallet and 1 roller). If it runs keep it as an ornament of the obstinate Swiss stubborness to resign themselves to the superoirity of the "lever" type escapement design. If it does not run, I would sell it for "steampunk parts" on eBay!
btw, I might have a matching Hr Hand. (Only if it runs)
posted August 02, 2012 17:53
Thanks David,
No it doesn't run, the third wheel pinion is broken. I had an Idea it was something like that. Would you like the hour hand just in case you might have use for it?
Thank you everyone.
