  What kind of movement?Go  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
| IHC Life Member  |
 I was wondering if anyone knew what this might be.  | ||
| IHC Life Member  |
 the piller plate  | |||
| IHC Life Member  |
 the case is No 18 fine silver, and it says cylindre 10Rubis, then Geneve. The inside cover has a number 48862 and has the word CUIVRE after it. By the way, the case number is the same as the movement number. Thank you for any help. Regards, Larry  | |||
| IHC Life Member  |
 the dial has no name  | |||
| IHC Life Member  |
 Everything came in this holder.  | |||
| IHC Member 1610 |
 Sorry Larry I can't hep but I like that minute hand.  | |||
| IHC Life Member  |
 Harry,  It's a little rough, but if you want it I'll send it to you. Regards, Larry  | |||
| IHC Member 1610 |
 Thanks Larry but I would not have an hour hand to match it. It would be cool if I did though. Thanks anyway, Harry P. S. I heard about the case. Ouch!!! I hope you were able to save it.  | |||
 Larry, the 10 Jewel Cylinder movement is the same as a 15 Jewel "normal" movement because the Cylinder has no Pallet fork reducing the "count" by 5 Jewels (2 pivot, 2 pallet and 1 roller). If it runs keep it as an ornament of the obstinate Swiss stubborness to resign themselves to the superoirity of the "lever" type escapement design. If it does not run, I would sell it for "steampunk parts" on eBay! btw, I might have a matching Hr Hand. (Only if it runs)  | |||
| IHC Life Member  |
 Thanks David, No it doesn't run, the third wheel pinion is broken. I had an Idea it was something like that. Would you like the hour hand just in case you might have use for it? Thank you everyone. Regards, Larry  | |||
