|  | posted |
I recently got a Waltham P.S. Bartlett s/n 12543865. Can anyone tell me what the part number of the mainspring is? Thanks in advance...Paul |
| | | Posts: 122 | Location: Baltimore, Maryland in the USA | Registered: February 25, 2011 |
IP
|  | posted | |
Thanks Jerry. I am going to order one. Do you know if PTPW is still in or out? Paul |
IP
|  | posted | |
Jerry: Do you know what the original should be for this watch? Paul |
IP
|  | posted | |
| | | Posts: 6492 | Location: Southern California in the USA | Registered: July 19, 2007 |
IP
|  | posted | |
Hello Paul.... Here is a portion of pg. 29 of my parts manual.... Pay close attention to the ordering instruction at the top of the page since it is using Main Spring #2205 as an example.... This is the only information I have therefore you will need to make whatever assumptions you can from it....I hope this helps you.... Regards, Jerry  |
| | | Posts: 2828 | Location: California in the USA | Registered: June 23, 2008 |
IP
|  | posted | |
David & Jerry, Thanks for the info. Paul |
IP
|  | posted | |
Thx for the info and links also. Much appreciated.
R. Glenn
| | | Posts: 437 | Location: Ryde, Isle of Wight, United Kingdom | Registered: January 18, 2010 |
IP
