Elgin 571 with 24hr Dial "Click" to Login or Register
IHC Member 48
Picture of Keith Klimkowicz
posted May 21, 2009 16:56
Hi
Just aquired this from ebay. Does this case remind you of the #7 Hamilton case. Does this look like a proper combination for a Elgin.
Posts: 856 | Location: North Ridgeville, Ohio USA | Registered: November 19, 2002
IHC Member 48
posted May 21, 2009 16:58
Movement
Site Moderator
Picture of Tom Brown
posted May 21, 2009 17:20
Hi Keith
It looks like it has the cut out for the micro regulator screw on the balance cock, unless someone cut that out later.
I think the case back should be marked cased & timed by Elgin & perhaps made by the Star case co., I think the 571 was the only model that needed that cut out in the case.
Wristwatch Host
Picture of Tony Dukes
posted May 21, 2009 17:36
Keith,
The dial is Canadian and if the case is Canadian with the 571 cut out it could be original. What say you/////
Tony
Posts: 1953 | Location: Atlanta, Georgia in the U.S.A. | Registered: August 01, 2003
Railway Historian
Site Moderator
Picture of Larry Buchan
posted May 21, 2009 18:19
The case looks Canadian, probably made by the American Watch Case Co. of Toronto, Ontario. I have seen many Hamilton 992B's, late-model Waltham Vanguards, and Elgin 571's cased like this. And this would be the Canadian equivalent to the Hamilton Model No. 7 Railroad case.
Site Moderator
posted May 21, 2009 19:11
Thanks Tony & Larry for setting me straight, I only know about the US cased 571 I have, thanks for teaching me about Canada.
Picture of Jerry King
posted May 21, 2009 19:45
Keith, what does it say on the inside of the rear case cover...?
That will tell us everything....
I agree with Tony....
IHC Member 48
posted May 21, 2009 21:11
Hi
Thanks for the information.
Jerry, I do not have the watch yet and I will post a picture when it arrives.
Larry, I am hoping that it is a Canadian case.
Keith
IHC Member 48
posted May 23, 2009 01:37
Hi All
The watch arrived today and the inside of the case is.
FORTUNE 10k Gold Filled Case Made In Canada Sturby
The detent devise must be unscrewed because the stem just pulls out. Does any body have a picture to share on how this should look if properly installed?
Site Moderator
posted May 23, 2009 10:29
Keith
Not sure if this will be of much help, I can take the one I have apart if you need more.
diagram
IHC Member 48
posted May 23, 2009 15:52
Thanks, from this I should be able to fix mine if the parts are there.
Thanks again!
Keith
Site Moderator
posted May 23, 2009 16:20
Keith
Just let me know & I can take mine apart if needed.
