Elgin 571 with 24hr Dial
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/80210619
May 21, 2009, 16:56
Keith Klimkowicz
Hi
Just aquired this from ebay. Does this case remind you of the #7 Hamilton case. Does this look like a proper combination for a Elgin.
May 21, 2009, 16:58
Keith Klimkowicz
Movement
May 21, 2009, 17:20
Hi Keith
It looks like it has the cut out for the micro regulator screw on the balance cock, unless someone cut that out later.
I think the case back should be marked cased & timed by Elgin & perhaps made by the Star case co., I think the 571 was the only model that needed that cut out in the case.
May 21, 2009, 17:36
Tony Dukes
Keith,
The dial is Canadian and if the case is Canadian with the 571 cut out it could be original. What say you/////
Tony
May 21, 2009, 18:19
Larry Buchan
The case looks Canadian, probably made by the American Watch Case Co. of Toronto, Ontario. I have seen many Hamilton 992B's, late-model Waltham Vanguards, and Elgin 571's cased like this. And this would be the Canadian equivalent to the Hamilton Model No. 7 Railroad case.
May 21, 2009, 19:11
Thanks Tony & Larry for setting me straight, I only know about the US cased 571 I have, thanks for teaching me about Canada.
May 21, 2009, 19:45
Jerry King
Keith, what does it say on the inside of the rear case cover...?
That will tell us everything....
I agree with Tony....
May 21, 2009, 21:11
Keith Klimkowicz
Hi
Thanks for the information.
Jerry, I do not have the watch yet and I will post a picture when it arrives.
Larry, I am hoping that it is a Canadian case.
Keith
May 23, 2009, 01:37
Keith Klimkowicz
Hi All
The watch arrived today and the inside of the case is.
FORTUNE 10k Gold Filled Case Made In Canada Sturby
The detent devise must be unscrewed because the stem just pulls out. Does any body have a picture to share on how this should look if properly installed?
May 23, 2009, 10:29
Keith
Not sure if this will be of much help, I can take the one I have apart if you need more.
diagram
May 23, 2009, 15:52
Keith Klimkowicz
Thanks, from this I should be able to fix mine if the parts are there.
Thanks again!
Keith
May 23, 2009, 16:20
Keith
Just let me know & I can take mine apart if needed.
