  Howard casing answerGo  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
| IHC Member 179 E. Howard Expert  |
 I'm sure many of you have read the NAWCC message board thread about recasing/switching, over 350 replies and 12000+ views, it is a sensitive issue especially when it concerns early Howards. Here is my cure for the un-cased or improperly cased Howard that comes into my possession. I have been making my own movement holders machined out of aluminum and fitted with two and one/eight inch domed glass crystals. Total investment not counting my time, less than $5.00 each. My movements are protected, and since there's basically no empty Howard cases available, I believe it's the perfect answer to the problem. Harold ![]()  | ||
 Howard, Nice work. I went out this week and worked on sorting probably 500-700 movements this week. There were a few Howards in the bunch along with a plethera of others. The person understood that the early E. Howards were valuable but did not realize that without a case value is impacted. I will be seeing this person again to sort more watches. Can you give me an idea of a general percentage of value with and without the proper case? I realize this is a tall order but I dont do alot with the Howards and need to know. Thanks, Aaron Bereiter  | ||||
 Aaron, For a rough ballpark estimate, a common Howard movement only, as opposed to a gold or silver properly cased Howard watch, you're looking at a factor of roughly ten to one, i.e. a $100 movement would be worth about ten times that amount properly cased. Keep in mind that there are many other factors that can effect the value greatly either way.  Harold  | |||
 Harold, Great display case! I too would be into buying a few of these if you should decide to sell them. Nice work. B  | ||||
 Guys, having been the owner of a mini-lathe for a total of three weeks, with no prior machining experience, I can tell you I have great respect for the old casemakers of 120+ years ago!! Material costs hardly nothing, my time going through the learning curve, to make these, probably 4+ hours each. I'm still working on getting some bugs out but will consider making a few in the future for material and postage costs, but my machining skills have to improve a bit first!!   Harold  | |||
| Administrative Assistant |
 Harold,  I am in complete agreement with the others who have posted before me. That looks like time consuming high precision work, but there would surely be a market for your beautiful Howard movement cases. It's a great Idea! Dr. Debbie  | |||
| E. Howard Expert |
 Harold, Great work. Next, how about a hole for a winding stem so you can watch the stemwind movements run? I know, that would allow some dust in. That's the trade-off, I guess. Clint Geller  | |||
