Illinois Motor Barrell Question "Click" to Login or Register
posted August 06, 2007 12:48
Were all Illinois Bunn Special 16s movements marked "Motor Barrell" considered to be 60 hour movements?
Posts: 47 | Location: Hamlin, New York USA | Registered: March 05, 2007
posted August 06, 2007 16:11
The simple answer is no, not all "Motor Barrel" marked Illinois 16-size movements are 60-hour.
Fact is there were "Motor Barrel" movements sold by Illinois Watch Company prior to the "Sixty-Hour" mainspring introduction. There was also overlapping in production and additionally certain 60-Hour 16-size movements were not necessarily marked as such Roll Eyes so it can get a little confusing. If you provide your movement number that would help in narrowing down exactly what you have.
posted August 06, 2007 17:46
Thanks!
The movement # is 3654711. It is listed as a 16s Bunn Special 23j. Just wondering if "motor barrell" does indicate it is a 60 movement
thanks again!!!
posted August 06, 2007 17:56
The database says, no.
posted August 06, 2007 19:27
The first 60 Hr BunnSpecial was SN 4,492,501. These were model 14's. The model 13 was 60 hr and came out at SN 4,166,xxx. The model 13 is a 17S and is a Sangamo Special.
posted August 06, 2007 19:50
Thanks for the info. Just wanted to make sure before I committed to the purchase.
posted August 06, 2007 20:13
Foster,
So now you have three "NO" opinions! Smile
To flesh it out a bit further, according to the Illinois Factory Records your movement number 3654711 is a 16-size, Lever-Set, Open-Face, 23-Jewel, Model 11 Bunn Special from 1920 production. It is important to recognize the first 60-Hour Movements were not introduced until 1924 which is obviously 4 years later.
The earliest 60-Hour, 23-Jewel Bunn Specials show up in a run which began at the 4492001 movement number. But as stated earlier 60-Hour was phased in and there were many Non-60-Hour Bunn Specials intermixed into that and subsequent runs as well. This is a complicated subject. About beginnings, Tom is correct on the earliest 60-Hour Sangamo Specials (UN-MARKED 60-HOUR) at 4166001 movement number.
A lot of collectors and unfortunately many sellers improperly "assume" the three screws on a ratchet wheel or the words "Motor Barrel" mean 60-Hour Mainspring. Motor Barrel marking on a movement means Motor Barrel, the mainspring style is yet another matter. Rather than generalizing we should check the number.
Show your seller the real-deal below. Wink
Here is 4492519 among the first 60-Hour Bunn Specials...
posted August 06, 2007 21:13
Thank you to all for the info. Having access to such a large # of experts has made collecting so much easier.
Although it is not a 60 hour, I think I may buy it anyway. The movement appears to be very clean, it has a really nice montgomery dial and is in a Bunn Special Case.
Thanks again!
