'92 model Appleton Tracy questionGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 1110 |
I would like to ask if anyone can explain what the difference is between the standard 17J A.T.& Co. 1892 model, and the A.T.& Co. "Premier". I know that the standard model was a 3-position watch, and I've heard that the Premier could be 5-position adjusted.Is that true? I've never seen an old ad for a Premier grade to see if any different features were listed for it.Is the damaskeen pattern or overall finish work better on the Premier? Thanks....Ted Brown. | ||
Ted I am not familar with the watch but thought I would post what Ehrhardt shows. It lists the AT&Co 1892 as adjusted & the Premier as adjusted 3 positions. Tom | |||
After I posted the above, I found these images on the web, apparently Ehrhardt's book is wrong or I misread it. ![]() | |||
The plain AT&Co ![]() | |||
The one on the left is 1897,. and on the right is 1901, they both have the same damaskeening as do about 7 more ATCo's in my "bunch", and they all advertise as "P" grade. So what I need to know is how do we determine the "Premier" from the "rabble"? ![]() | |||
You can't see it in the ad that Tom posted about the Premier, but I found a larger version of the same ad and Premier is actually engraved on the barrel plate. | ||||
From searching images on the web it would appear the Premier grades have that engraved on the movement. ![]() | |||
| IHC Member 1110 |
Thanks, Tom, Mary-Ann,& Dave.I see that the only apparent difference is the 5 position adjustment on the "Premier".Mine is The standard model, it also has the same damaskeening pattern as the ones you show.They, like all 1892's , are a beautiful movement. | |||
