Lever Set in a Swing Out CaseGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 1541 |
I don't much like swing out cases but made an impulse buy of a Howard Series 10. It is LS in a swing out case. The only other swing out case I have has a PS movement and is easy to open as I just pull the crown to set position. I have read somewhere on this site that you should not pull the crown out on a lever set movement. If that is the case how does one swing the movement out on this watch. | ||
| Site Administrator IHC Life Member |
Lorne, you have to pull the crown up lever set or not, else you could possibly break the stem. | |||
| IHC Member 1541 |
Thanks Phil. | |||
