December 29, 2011, 16:06
Lorne WasylishenLever Set in a Swing Out Case
I don't much like swing out cases but made an impulse buy of a Howard Series 10. It is LS in a swing out case. The only other swing out case I have has a PS movement and is easy to open as I just pull the crown to set position. I have read somewhere on this site that you should not pull the crown out on a lever set movement. If that is the case how does one swing the movement out on this watch.
December 29, 2011, 16:55
Phillip SanchezLorne, you have to pull the crown up lever set or not, else you could possibly break the stem.
