  Waltham Serial Number siteGo  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
| IHC Member 1610 |
 Our Waltham serial number look up site has been down for quite awhile or at least I can not access it. Do we have another site we can use to get information on a Waltham as far as grade and total production. I do not want to use the pocket watch data site as a lot of the infor from there is iffy. That site says only 300 where made but another site I checked shows the same model with a lot more being made but it doesn't list the serial number range mine watch in question is in. The serial number is 2634109. Thanks, Harry  | ||
 Harry - What model is your Waltham? According to Waltham Serial Lists, this run (2634001-2634200) is designated as a Model 1877 Grade No. 35. If this is true, the total production is indeed 300. If you find your model to be classified as a Model 1883, the estimated production numbers will obviously change. Keep in mind these resources are only as reliable as the original records available. The Waltham factory records are notoriously inconsistent.  | ||||
| IHC Member 1291 |
 A Model 1877 Grade 35, made in two runs from May 1886- Dec 1886 with 300 Total Produced. A Full Plate 18sz, H/C movement of 15 Jewels with a Patent Regulator and Brequet hairspring. regards, bb  | |||
| IHC Member 1610 |
 Thank you Nathan and Buster. Yes it is a model 1877. I guess I did ok with this one. Harry  | |||
