August 17, 2018, 20:56
Harry J. Hyaduck Sr.Waltham Serial Number site
Our Waltham serial number look up site has been down for quite awhile or at least I can not access it. Do we have another site we can use to get information on a Waltham as far as grade and total production. I do not want to use the pocket watch data site as a lot of the infor from there is iffy. That site says only 300 where made but another site I checked shows the same model with a lot more being made but it doesn't list the serial number range mine watch in question is in. The serial number is 2634109.
Harry
August 18, 2018, 08:53
Nathan MooreHarry - What model is your Waltham? According to Waltham Serial Lists, this run (2634001-2634200) is designated as a Model 1877 Grade No. 35. If this is true, the total production is indeed 300. If you find your model to be classified as a Model 1883, the estimated production numbers will obviously change.
Keep in mind these resources are only as reliable as the original records available. The Waltham factory records are notoriously inconsistent.
August 18, 2018, 09:37
Buster Beckquote:
2634109
 A Model 1877 Grade 35, made in two runs from May 1886- Dec 1886 with 300 Total Produced.
A Full Plate 18sz, H/C movement of 15 Jewels with a Patent Regulator and Brequet hairspring.
August 18, 2018, 11:47
Harry J. Hyaduck Sr.Thank you Nathan and Buster. Yes it is a model 1877. I guess I did ok with this one.
Harry
