Manhattan Serial Numbers?Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 660 |
Manhattan Serial Numbers? Can we compile serial number data on Mahnattans and New York Chrongraph watches & movements? I will be glad to put it all together (maybe a little slowly). The main items seem to be: Movement serial number Case material - nickel/gold fill/decoration/etc. Case Style - Open/hunter Sweep hand - yes/no (if minute post is hollow, there is supposed to be a sweep hand) Stop mechanism - yes/no (there will be two small buttons instead of one) Barrel bridge - yes/no Winding click - pivoted & spring, or one piece Dial - paper/porcelain Chronograph - yes/no (angled button at 11:00, & watch continues running when timer stopped) 3/4 plate 16 size - yes/no Would love to get data and an understanding of Manhattan production. Mike | ||
Hi Mike, I've had two but I kept no ser.# record. There was one at the flea last Friday though. If it's still there this Friday I'll grab the description and number. -Cort | ||||
Mike, I have two as follows: No 1. SN 151113, white metal case with no markings except the number 59, the case is hinged front and back and no dust cover, it has a plain finish with a rather nice engraving on the back of two horse heads as if they were racing. It has a sweep second hand,porcelain dial with arabic numerals and marked "Manhattan Watch Co" I believe it is a chronograph as the button at 11 operates radially. Has a barrel bridge (as shown in Townsend). Open face. No 2. Just a wreck with the back plate and most of the mechanism missing hence no serial number. Sweep second, open face with a stop mechainsm that operates parallel to the stem and which stops the balance. Porcelain dial with roman numerals and marked "M W Co". The case is gold filled, open face, screw back and bezel. The engraving is a common floral pattern and inside the back cover it is engraved "Fahys Montauk No 1" and separately "M W Co". I hope this (poorly organized) information is of some use to you. Happy to answer more questions. Maurice | ||||
| IHC Member 660 |
Thanks Mauarice, all the little bit help. Mike | |||
