  992E case  questionGo  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
 can 992e movement be in model A case  movement is from 1939  | |||
| IHC Member 1338 |
 Peter; I'm not an expert on this, but I would rather see it in a Model 10 or Model 2 case. Given the date I suppose it would be ok, Ed P could tell you for sure.  | |||
 Peter, I am guessing the 992E movement is from the 6-9th run 2,619,001 - dating to 1939 to the last run in 1940 with a serial # before 2,655,300. Still don't think the model A would be correct Would go w/ model 2 or 10 - like Tom stated - the few later #s E's I have seen are sporting them...  | ||||
 I just got the movement and have model A case sitting empty thuse the question.  | ||||
| IHC Vice President Pitfalls Moderator IHC Life Member  |
 Peter, Tom has a good point, a Case 2 or 10 would definitely be a more "non-argumentative" case, but a Case A could be correct under certain circumstances . . . As Jon pointed out, the Hamilton/Keystone Case Model A didn't start until 1940, so it wouldn't be correct unless you have a 1940 watch, which would be from one of these 2 runs of 992E: 2641001-2649000 2651001-2655300 THe Case A would have to be shouldered and have a very low case number (see photo) to make it credible. 1940 Hamilton Case A Signature ![]()  | |||
 Thank you all looks like it will be ok  since the Serial# is 2641739 on the 992e Ed what is shouldered? and my case serial# is K068055  | ||||
 Peter, Your Case A would need pendant shoulders (see photo) to have any credibility on a last run 9902E. To be considered strictly correct for 1940, the case number would have to be all numbers, with the first 3 digits 120 thru 124. The K prefix started later. Case A w/ Shoulders (1940-1948) on the left -- w/o shoulders (1949-1954) on the right ![]()  | |||
 There might be an issue w/ case screws marks possibly not lining up - if the model A originally housed a 992B movement     | ||||
 Yes, that's a potential issue if the marks don't match and they're too deep to polish out. Best Regards, Ed  | |||
 Thanks I have case model10 but not in the best shape  ring of brass on back and model A is in better them good condition.  | ||||
