992E case question "Click" to Login or Register
Picture of Peter Kaszubski
can 992e movement be in model A case
movement is from 1939
Peter; I'm not an expert on this, but I would rather see it in a Model 10 or Model 2 case.
Given the date I suppose it would be ok, Ed P could tell you for sure.
Tom Dunn...
TIME MACHINE
www.myrailroadwatch.com
Peter,
I am guessing the 992E movement is from the 6-9th run 2,619,001 - dating to 1939 to the last run in 1940 with a serial # before 2,655,300.
Still don't think the model A would be correct
Would go w/ model 2 or 10 - like Tom stated - the few later #s E's I have seen are sporting them...
Smile
I just got the movement and have model A case sitting empty thuse the question.
IHC Vice President
Pitfalls Moderator
Peter,
Tom has a good point, a Case 2 or 10 would definitely be a more "non-argumentative" case, but a Case A could be correct under certain circumstances . . .
As Jon pointed out, the Hamilton/Keystone Case Model A didn't start until 1940, so it wouldn't be correct unless you have a 1940 watch, which would be from one of these 2 runs of 992E:
2641001-2649000
2651001-2655300
THe Case A would have to be shouldered and have a very low case number (see photo) to make it credible.
1940 Hamilton Case A Signature
Thank you all looks like it will be ok
since the Serial# is 2641739 on the 992e
Ed what is shouldered?
and my case serial# is K068055
IHC Vice President
Pitfalls Moderator
Peter,
Your Case A would need pendant shoulders (see photo) to have any credibility on a last run 9902E. To be considered strictly correct for 1940, the case number would have to be all numbers, with the first 3 digits 120 thru 124. The K prefix started later.
Case A w/ Shoulders (1940-1948) on the left -- w/o shoulders (1949-1954) on the right
There might be an issue w/ case screws marks possibly not lining up - if the model A originally housed a 992B movement Eek
IHC Vice President
Pitfalls Moderator
Yes, that's a potential issue if the marks don't match and they're too deep to polish out.
Thanks I have case model10 but not in the best shape
ring of brass on back and model A is in better them good condition.
