IHC Member 1101 Site Moderator |
Hey all, I am curious. Many movements, Illinois in particular, have black, red, or gold filled engraving on the movements. How is that done and can it be redone after it has worn away? Steve | ||
IHC Life Member |
I have EXACTLY the same question. Lindell, please hop in your time machine and go back to Illinois and find out how they filled those engravings. Puleeeze? | |||
IHC Life Member Site Moderator |
I thought I would add my two cents, for the black letters I have used a Sharpie marker. I just fill in the letters or numbers & the area around it & then immediately wipe it off with a cloth & it stays in the writting but comes off everything else. Now I have to warn you, this works for me & I have never had it stay on the movement or pattern on the movement but try it at your own risk. Tom | |||
IHC Life Member South-Bend |
Car paint is very tough and comes in quite a few colors. Nail polish enamel is not quite as tough but comes in an amazing shade of colors. There are a few of the opaque red colors that can successfully be used to refill in the red numbers on the 19j Ball specials. You can get good results with a marker but they don't last that long and to a trained eye it looks wrong. | |||
Frank, Where do you find that paint at? Auto parts store? Car dealer? Does it stand up to cleaning? Thanks, Steve | |||
Yes, you should be able to find it at an auto parts store. It stands up to cleaning. | |||
This is my 23 jewel 60 Hour after refilling the engraving using Testors Black Enamel Modeling paint. The lettering was completely washed out except for a small section of the underline under Bunn Special. I found it works best to do a section at a time and dab with a small paintbrush, just enough to fill in. Then wait a minute (literally) and begin scraping off the excess with a tootpick. Keep a box on hand because they work best when they are clean. I can't believe the picture came out so good. Anyway, this worked for me and the paint cost $1.37 at the drug store. I did about 15 movements in about 2 hours. Steve | |||
