Picked up an 18s Hampden model 3 grade 55 that needs a good clean, but is running. It has a later 1900's style case which I'll change to a period correct one. The dial is also later style. So my questions are. Will a Dueber triple-hinge coin case be correct? Or back then did Hampden not really come with Dueber cases? Secondly I have a dial that I'd like to use on this 1886 movement is it correct enough?
R. Glenn
Posts: 437 | Location: Ryde, Isle of Wight, United Kingdom | Registered: January 18, 2010
And here is the case I'd like to use. I have since replaced the crystal with a thicker bevelled edge. Will all of this be a better match for the era? Thank you all, Roland.
R. Glenn
Will a Dueber triple-hinge coin case be correct?YES Or back then did Hampden not really come with Dueber cases? BACK THEN THAT IS HOW DEUBER GOT SO INTERESTED IN HAMPDEN, THEY WERE A GOOD CUSTOMER. Secondly I have a dial that I'd like to use on this 1886 movement is it correct enough?YES, BUT THE HANDS ARE MORE LIKELY CORRECT TO WHAT YOU HAVE NOW.
Hi Roland, I think you have the right idea, that dial would be about right for it.Your watch has the Tucker regulator, which is less common than the Teske reg. which were on a lot of Hampdens.Looks like the Roman dial has a long hairline down thru the center.If you're interested, I have one like yours in better shape, or a true double sunk Roman dial off an early OF Hampden, maybe we could make a trade.I could use a later style like yours.Not all 18S Hampdens, especially the Springfield ones were in Dueber cases.I think (but may be wrong) that a case for a watch that old would have had a stem retaining screw in the neck below the crown, instead of a screw-in sleeve/stem combination.Looks like a nice watch you have there!...Ted
Posts: 1323 | Location: Lebanon, Connecticut USA | Registered: March 28, 2008
Hi Theodore, the roman dial has no hairlines, just a slight nibble at the seconds hole, which I'll cover with a different seconds hand, so should be fine. Thanks for the offer though.
Roland.
R. Glenn
Everything on my watch is original to the watch. Nothing has been changed since he purchased the watch in 1890, and it's been in the family all this time.
As you can see, it has the moon hands like your second watch.
I guess what I'm trying to say is based on what I personally own, the combination of what you propose would have comparibles to my existing watch, that being they came that way from Hampden when they were brand new.
Regards! Mark
Posts: 3839 | Location: Estill Springs, Tennessee, USA | Registered: December 02, 2002
Well I've switched bits and here's the finished pocket watch. Unfortunately I wasn't able to use the Dueber case as the winding stem wasn't long enough to be able to wind the movement. So I've used a Fahys Oresilver case with a thick crystal with a patent date of 1884, so that should work with a movement from 1886. What do you think? Thank you, Roland.
R. Glenn
Thank you Ted. I have a few Gilt oldies and since they were a cheaper grade back then, it seems only fitting to have them in either a coin case or the like. Thx again, Roland.
R. Glenn
