Just a tidbit of info on some of these earlier Rockford's, in the first 15,000 produced on the numbers we have at present there are approximately 16 changes backwards and forwards between the Model 1 & 2's. Also within those first 15,000 there are more then 75 Grade changes (of the available Grades of the time), so as you see it will take a lot of numbers to find out what, when and how many of these differences there are.
So I implore anyone with numbers or examples laying around could you please contact me or upload photos and details of what you have (if unsure photos speak a thousand words, this info should include if possible; serial, model type, if stem & lever or key-wind & set and jewel count) if you have not already done so, thanks to all for their contributions to date and thanks for any that are forthcoming
Posts: 2264 | Location: Gladstone in Australia | Registered: January 14, 2011
Hi Bila> Re: #156367 Hopefully the enclosed picture will show this movement (it is a picture I have on file) . Just got a new computor operating and hopefully got the "compressing" thing figured out. Maiden try!. If it is succeccful and you would like to see other pics of it let me know.
Posts: 361 | Location: Kincardine, Ontario in Canada | Registered: November 25, 2013
Appears to be a 9 Jewel Model 2 stem win & lever set John, can you confirmed that it only has the 2 jewels on the back plate, as the 2 pivot holes under the balance wheel are hard to see?
Holes under balance wheel are jewelled. I had thought from my other pics that they were not jewelled but it was bothering me a bit so I dug out the watch to see and they are definatly jewelled holes in the back plate. The front I am not sure. As I have it out would you like me to check under the dial. John
Hi Bila. Looked at front plate and those two holes are not jewelled. I took pics but for some unknown reason cannot download to computor.If/when I get that sorted I will post. John
Also John is it possible to see a better view of those to hole jewels on the back plate to see how they are fitted, as the hole sizes look smaller then they should be for a factory job?
Excellent John Thank You, this is what Rockford called "Plain Jeweling" in their Grades. Also this one has created another different data point in the serial database.
Thank you Douglas, these 2 cleared up a couple of errors, the 7 jewel had erroneously been reported from another source as 9 jewel and the other was originally seen in a key-wind case but yet fell in a run of Mode 2 transitional's, so info very much appreciated
For all who are interested in these earlier Rockford production runs just a tid-bit of an update regarding the chopping and changing of movement variants.
I have just briefly gone through the first 40,000 serial numbers (based on the small selection we have at present) and have found that the Models as designated (based on the model 1 & 2's and the like) changed backward and forwards 55 times in this first 40,000 numbers and the variances within those model changes show 160 different Types/Grades (these different types refer to jeweling and the like but not including variances in font and other attributes). These numbers could change to a degree as we get more added to the database.
So as you see to work out exactly what was produced by the Rockford Watch Factory a lot more numbers will be needed. So if you have any please put them forward for this important research. Also for those that have already, your participation is very much appreciated
Here's one for your list, Bila. 18s serial # 140222. 13 jewels. Third and 4th wheels jeweled only on back plate. Lever set, stem wind, Hunter case gilt movement with pinned on dial. Marked EXTRA on mainspring bridge.
Posts: 692 | Location: Washington in the USA | Registered: May 23, 2010
